davorin
100% infill and solid outer fill printed separately
Sat Feb 02, 2019 6:04 am
Good morning
To increase the stiffness of some objects I want to print the infill also with 100%.
Is there a way that the code generated doesn't print both 100% fill separately?
thanks in advance
richard
Re: 100% infill and solid outer fill printed separately
Sat Feb 02, 2019 5:31 pm
Please,
what do you mean " solid outer fill" is? Perimeters? Or top- and bottom layers?
GER
jgomes0
Sat Feb 02, 2019 5:44 pm
One option is to increase the bottom and top layer counts to add up to the entire height of the model.
TN Yankee
Sat Feb 02, 2019 7:55 pm
And another option, depending on your software capabilities: Load dependent Infill placement.
JimEdmiston
Wed Feb 06, 2019 1:29 pm
I don't think those infill rules apply to the first layer so much. The empty space is the slicer not able to fill the small gaps. You need to look at single extrusion settings or maybe something simpler like the first layer width percentage.
