Primary width / height less than 1.2 issue
Posted: Wed May 15, 2019 10:19 am
by Ronald44182000
I keep getting this response when I attempt to print with PETG in the latest version of Simplify3d and can't figure out how to change the settings. HELP??????????????
Re: Primary width / height less than 1.2 issue
Posted: Wed May 15, 2019 2:53 pm
by S3D-Jake
Check your Extruder Tab -> Extrusion Width / Layer tab -> Layer Height Ratio. If it's less than 1.2 you should adjust your extrusion width / layer height settings. Typically this means you need to use a thinner layer height or wider extrusion width.
