Any Modix Big60 tips?
Posted: Fri Jun 14, 2019 5:53 pm
by Don
I'm a long-time Simplify3D user, and at the moment I have 9 boxes in my garage, a Modix Big60 (some assembly required).
I've downloaded the profile, and am looking forward to 4 week prints (yikes), but while I slowly assemble this thing, I thought I might ask fellow Simplify3D users if they have any experience and tips with this printer they might want to share.
I bought it because I have several large prints coming up in the near future, and I'm tired of glueing together parts for the final.
Any input welcome!
Thanks,
Don
Re: Any Modix Big60 tips?
Posted: Tue Jul 02, 2019 11:55 am
by ngoldberg
Hello,
I have assembled and been using a Modix for over a year and may be able to help.
The manual is generally very good but some of the pictures may be a bit confusing
It is helpful to have a decent metric capable caliper available. I also found a high quality inch / metric tape measure on the McMaster website
1) The allen wrenches included with my kit were only slightly harder than frozen butter . Get a better set to be able to tighten screws better.
2) Do your assembly on a clear CLEAN, non carpeted floor that is measured to be level. Work on cardboard to avoid scratching.
3) When assembling the frame, work carefully and do not tighten an assembly until all screws are in place. Insure that there are no aluminum chips on the mating surfaces.
4) Then go back and tighten everything, before the Loc Tite has had a chance to set up.
5) Heed the caution in the manual about being sure that the right frame pieces are used in the proper locations other wise the whole frame will be out of square.
6) Avoid screwing in the feet into the frame until you are absolutely sure that everything is square.
7) The drive pulleys are all really soft aluminum be careful tightening them so as not to over tighten. Mind the location of the flats on the motor shafts.
I will try to answer any other questions you might have but I do not check this forum every day.
Regards,
Neil
Posted: Mon Oct 14, 2019 9:35 pm
by pcarrillo
Neil,
I have the Modix big 60 and installed the 2nd extruder/hotend, I can get both to extrude but cannot in conjunction with one model, meaning, extruder 1 prints the perimeter & infill and the supports, but I need the 2nd extruder to print the supports only. when the model is finished, I want to place in water remove the supports only. Do you know how to set up 3Dsimplify step by step so i can accomplish this? Any assistance would be much appreciated.
Thank you,
Posted: Fri Oct 25, 2019 6:08 pm
by Don
Neil,
Thanks for your response.
My printer is up and running and I'm amazed by the prints.
It took a couple weeks.
One of my best finds was to print with zero bottom layers. I had a fair amount of curling on large, flat prints. But I saw that the brim and the walls all laid down flat. So I turned off the bottom layer. Honeycomb starts straight on the bed. I haven't had a problem since.
Printing PLA at 205 at 40 mm/sec at .15 height with .4 nozzle, no bed temp. I'm at the point where I set up the print and leave the room. Perfect prints every time. Prints pop off the bed with no problem. I did kill my first layer of PEI when calibrating.
Don
