SuperSport
Will Simplify3D install on MacOS Catalina? 64 Bit
Sat Jul 27, 2019 2:08 pm
If I purchase S3D, will it install on macOS Catalina? I realize it's a 64 bit program, but it maybe uses a 32 bit installer??? I'm currently running Catalina Beta and would like to install on there if possible.
TheBum
Re: Will Simplify3D install on MacOS Catalina? 64 Bit
Mon Jul 29, 2019 11:49 am
It runs fine for me on Catalina Beta.
SuperSport
Wed Jul 31, 2019 8:32 pm
Did you upgrade to Catalina after S3D was already installed? My understanding is that S3D is 64 bit, but the S3D installer is 32 bit and Catalina will only run 64 bit software.
TheBum
Thu Aug 01, 2019 12:42 pm
I don't think I've tried installing it since I started using Catalina beta. I can try it this evening if I remember. I assume you're trying to hold off buying it until you're sure you can use it right away?
TheBum
Fri Aug 02, 2019 12:32 am
I just tried it. The installer runs just fine on Catalina beta.
