efarrand
Idle Extruder Temp
Sat Oct 26, 2019 11:48 am
How do I set my right extruder to an Idle(lower) temp when it's not being used during a dual extrusion print. and then have it heat up again when it's needed to print?
Thanks for your help
S3D-Chris
Re: Idle Extruder Temp
Mon Oct 28, 2019 1:57 pm
Take a look at this tip of the day post: viewtopic.php?t=1959
You can also check the Ultimaker 3 tool change script as an example of using scripting to implement idel temperatures.
