gudankou5
What stepper mtor do you guys use for 3D Printer?
Fri Jan 17, 2020 5:46 am
What do you guys use for 3D Printer?
NEMA 17 stepper motor?
how about the following stepper motor?
nema17:
https://www.oyostepper.com/goods-494-St ... 404S1.html
https://www.oyostepper.com/goods-50-Nem ... ector.html
Nema 23:
https://www.oyostepper.com/goods-75-Dua ... Wires.html
https://www.oyostepper.com/goods-65-Nem ... Wires.html
Which is better for 3d printer? nema 17 or nema23?
Thanks for your suggestion?
Ret
Re: What stepper mtor do you guys use for 3D Printer?
Sat Jan 18, 2020 12:44 am
Moons' makes great steppers. I've switched most of my steppers to moons' since they're very well built, quieter, accurate, and have less vibration than most. On most desktop printers, you won't find anything but nema 17's, which can do the job fine. Ultimaker also uses Moons'.
https://www.moonsindustries.com/c/hybri ... tors-a0201
arhi
Sat Jan 18, 2020 10:06 am
it depends on so many things
- what type of printer
- what type of axis
- what driver
- what voltage
- what speed ...
you can find out something on this calculator for e.g. ... the max speed you can expect from a motor based on it's parameters and what voltage your driver uses: https://www.reprapfirmware.org/ (click on emf calculator)
much more calculation and explanation here: https://www.orientalmotor.com/technolog ... tions.html
Embed M117 codes into G-Code
open source and unlicence
