toppilot
Print two halfs
Sun Feb 23, 2020 10:18 am
I am trying to print something from thingyverse but is slightly to wide, how can I print it in two halfs? Thanks
billyd
Re: Print two halfs
Mon Feb 24, 2020 9:48 am
Drop the model to the build bed. Then double click on the model and change the existing z coordinate by negative the amount of mm's you want below the bed. It will slice and create the gcode for only that portion at and above the build bed.
Then rotate the model 180 degrees in Y and redo the slicing in the same manner for the other side.
TheBum
Re: Print two halfs
Tue Feb 25, 2020 7:01 pm
Another option is to load the model into an application like Meshmixer and do a plane cut on it. Export the two halves.
toppilot
Re: Print two halfs
Wed Feb 26, 2020 12:06 pm
Thanks I will give it a try at the weekend
