rapapar
preview speed scale change
Fri Apr 24, 2020 12:56 pm
Hello,
from a project to another, the Speed scale with color in the "coloring mouvment speed" option of the preview mode windows is not always the same
sometime 70mm/s is red sometime it is 100mm/s
Do you know why ?
DennisLee
Re: preview speed scale change
Sun Apr 26, 2020 1:17 pm
Hey. What is your default print speed?
ParzivalR
Tue Apr 28, 2020 10:13 am
Hi!
The color scale depends on the assigned Maximum and Minimum speeds. It is a comparative allocation.
In case "X / Y Movement speed" is higher than "Default printing speed" you will see this as the maximum value of the scale.
-If for example you set 80mm / s for "Default printing speed" and 10mm / s for "X / Y Movement speed" you will see that the model layers will be yellow and red.
-if you set 80mm / s for "Default printing speed" and 200mm / s for "X / Y Movement speed" the layers of the model will have a green tendency because compared to 200mm / s the printing speed is much lower.
Cheers!
