SHoutzager
Moving the Center point
Tue Oct 06, 2020 4:36 pm
I have a model that I imported into S3d and the center point is off to one side. I need it dead center of the object. How to control it? 8-)
Re: Moving the Center point
Tue Oct 06, 2020 9:07 pm
Go back to your CAD package and sort the centre out there!
SHoutzager
Wed Oct 07, 2020 9:52 am
The center point is controlled by S3D. This is the same part and the center is always aligned to the bottom.
parallyze
Wed Oct 07, 2020 10:38 am
There's coordinates inside the STL files. What happens when you import them in S3D depends on settings. And as
far as I can tell STL files don't include a pivot point like you can specifiy in 3d applications (blender/max/f360).
Sometimes models get sliced into multiple parts after designing. Often these parts are already in their correct position, but will get arranged on
the bed automatically (Tools -> General Options -> Models -> "Automatically center and arrange imported models").
Example object, sliced into 3 pieces:
3 STL files Imported with "Automatically center..." enabled:
Same STL files with "Automatically center..." disabled:
The transform gizmo in S3D seems to always center to the selected objects x/y dimensions and it's minimum point along Z.
