Klippan
Layer Starting Point
Thu Oct 15, 2020 2:42 am
I would like to use ”Choose start point closest to specific location”
Is there any easy way to get the coordinates of a specific point in the X-Y plane on the part to print?
You can also imagine moving a specific point on the part to a specific coordinate.
//LOA
Start Point.jpg (11.01 KiB) Viewed 114 times
parallyze
Re: Layer Starting Point
Thu Oct 15, 2020 10:52 am
An "easy" way to get the exact point is using something simple as a 1mm x 1mm x 250mm box STL:
Box placed where I'd like to set start points. Dragging the box around using CTRL+LMB works well here.
Retracts aligned between back/sword (X/Y 115/85):
Don't forget to remove the box afterwards (or exclude it from the selected models list within the process).
Added something like this in a thread here: viewtopic.php?f=23&t=5965&p=56749#p56749
(model: https://www.thingiverse.com/thing:33804)
