20181105ok
prevent suppot in a small hole?
Mon Feb 01, 2021 8:47 am
I have a small hole in the bottom (diameter=6mm, depth=6mm, see picture) of the printed part.
How can I prevent support being generated in the small hole? Thanks!
gwhite
Re: prevent suppot in a small hole?
Mon Feb 01, 2021 10:04 am
One trick is to make the top of the hole conical. If the cone is at a steep enough angle, it won't need or generate supports. If the hole HAS to have a flat top or you can't edit the file, you can go into the supports menu on the right side of the main display, and remove just those supports. It looks plenty small enough that bridging should work quite well.
20181105ok
Mon Feb 01, 2021 10:35 am
Hi @gwhite The hole top need to be flat. I see the Customize Support Structures button. Thank you!
billyd
Mon Feb 01, 2021 7:13 pm
Use manual supports. Click on auto generate supports. Remove the supports it creates in the hole.
20181105ok
Tue Feb 02, 2021 3:03 am
@billyd Thank you for your suggestion!
