One trick is to make the top of the hole conical. If the cone is at a steep enough angle, it won't need or generate supports. If the hole HAS to have a flat top or you can't edit the file, you can go into the supports menu on the right side of the main display, and remove just those supports. It looks plenty small enough that bridging should work quite well.
