Hello,
I am new to Simplifyd and I am running into an issue. I am trying to print an object and some of the top layers are printing like infill, you can see where this is happening in the picture as anywhere there is light green the print layer is very thin. Is there a way to disable infill on the top 100 layers, I have tried using the Variable Settings Wizard and the top layers are still the same.
Thank you
