Page 1 of 2
Tip of the Day 17 -New Feature- Horizontal Size Compensation
Posted: Wed Feb 04, 2015 10:23 am
by KeyboardWarrior
The horizontal size compensation is a new feature in version 2.2.2, if you don't see this option under the Other tab, this may mean you are using version 2.2.1 or earlier. There are many, many usage case scenarios for which you could use this feature. Taken from the blog post, the gear bearings by Emmet. If you print these out, and the plastic has molded together, you could place a value of -.05 to increase the gap by 1. mm, or -.1 mm gap to increase the gap by .2 mm (half the average nozzle diameter for perspective). the gap is doubled, since both perimeters are compensating away from one another, so the gap is twice the value of the input.
http://www.thingiverse.com/thing:53451
That's one use case scenario, but there's also the use case for a standard print. For instance, if you print a 25 mm cube and notice that it's 24.8 mm in the X-Y axis, then you print a 50 mm cube and it's 49.8 mm, you could add .1 mm to the size compensation to quickly remedy the size of your prints.
Re: Tip of the Day 17 -New Feature- Horizontal Size Compensa
Posted: Wed Feb 04, 2015 3:34 pm
by BaronWilliams
This is a great new feature of version 2.2.2. It's very helpful when printing functional parts that interact with each other.
I wonder why slicers do not normally have this on the Z axis as well?
Posted: Thu Feb 05, 2015 5:48 am
by AndersE
Wow, this was really cool to play with :)
Posted: Fri Feb 06, 2015 8:10 pm
by 66tbird
It's what I've been needing, Thank you :D
Posted: Mon Feb 09, 2015 11:37 am
by kenwshmt
This may help mold making too, since the outside edge is slightly larger than it should be for a negative mold.
http://www.thingiverse.com/thing:31581
any thoughts?
Posted: Mon Mar 02, 2015 10:34 am
by FrankBlack
Lets say holes usually come out .5mm too small. Would it make sense to keep this setting as .25mm?
Posted: Sun Mar 08, 2015 11:26 am
by JoeJ
You would want a negative 0.25mm so it makes the holes larger. But yes, the value of -0.25mm is correct, since that will take 0.25mm out of each side of the hole, making the diameter 0.5mm larger
Posted: Fri Mar 13, 2015 1:57 pm
by bapro
When pointing your mouse at this feature it says (shrink)???? Please change this to offset if that's what happens. Shrinks gives more of a feeling of scaling that is something completely different.
Posted: Thu Mar 26, 2015 4:48 pm
by adamfilip
BaronWilliams wrote:This is a great new feature of version 2.2.2. It's very helpful when printing functional parts that interact with each other.
if your Z Steps are right. then
Z can be adjusted using the Extrusion multiplier. up to a point..
when i notice something is shorter then normal. i adjust my extrusion multipler slightly higher, it usually helps.
Posted: Fri Apr 10, 2015 4:47 pm
by Wolfie
Wait, what? I was under the impression that "Extrusion Multiplier" affected how much material was extruded, not the actual z steps. Was I wrong?
