Obfuscated
Is anyone having luck printing .1 mm with Replicator 2x?
Sun Jul 07, 2013 10:15 pm
Is anyone having luck printing .1 mm layers with Replicator 2x? If so what settings are you using?
Obfuscated
Re: Is anyone having luck printing .1 mm with Replicator 2x
Sat Jul 20, 2013 12:28 am
So after alot of fiddling I've been able to do some decent prints at layer heights of .1.
Extrusion Diameter .4 mm
Auto Extrusion Width .9 mm
Extrusion Multiplier .7 mm
Phgeis
Tue Sep 03, 2013 5:01 pm
I am fighting with mt 2x on .2 mm . Could you give me a hint where your importations are around? I use right now
Nozzle .4
Width .36
Multiplier 1.1
I am not totally satisfied with the result
These seam totally different from your .1 values. Can you help me underfunding these parameters?
Enginwiz
Sat Sep 07, 2013 4:08 pm
The Replicator 2 can do 0,1 mm prints in PLA.
You can see pictures of my 0,1 mm prints on
http://www.thingiverse.com/thing:147628
Search for "Simplify3D Creator profiles for PLA" and download the .factory files.
Happy printing!
Obfuscated
Tue Sep 10, 2013 1:13 pm
Phgeis wrote:I am fighting with mt 2x on .2 mm . Could you give me a hint where your importations are around? I use right now
Nozzle .4
Width .36
Multiplier 1.1
Nozzle is of course pretty much whatever your nozzle diameter is.
Width is the size that the extrusion comes out of the nozzle. I think that's including the width it gets squished out to. So it's reasonable to assume it will be always be larger than the nozzle diameter. This setting will effect the amount of spacing being shells.
Multiplier will change the amount of plastic coming out of the nozzle. ABS tends to expand more than PLA. So this value for ABS should be smaller than PLA. Also the smaller the layer height the smaller this value should be.
Enginwiz
Wed Sep 18, 2013 9:33 am
During calibration I measured the extruded path width on the printed parts several times. The sharp tip of the MK 8 nozzle doesn't squish out the extruded plastic. With the right amount of plastic extruded the extruded path is a little bit less than 0,4 mm wide. I used 0,4 mm as a standard extrusion width for all layer heights and got very good print quality with this setting.
