Page 1 of 2
Pause at z pos
Posted: Mon Apr 20, 2015 9:12 am
by GregFisk25
How do you script multiple pause at zpos?
I have seen the code somewhere, but have looked and looked but cant find it.
I dont want to enter M0 into the code, as there is a simple way of putting it into the script tab, but I cant find it.
Re: Pause at z pos
Posted: Tue Apr 21, 2015 6:22 am
by JoeJ
You could put something like this in your post processing script
{REPLACE "; layer 100" "M0\n; layer 100"}
That will add a pause right at the start of layer 100. If you need more exact positioning for the pause location, then just open up the gcode file in a text editor and add the "M0" command wherever you want it.
Re: Pause at z pos
Posted: Tue Apr 21, 2015 10:41 am
by KeyboardWarrior
JoeJ wrote:You could put something like this in your post processing script
One thing to note on this, is that if you have over 1000 layers, that it will also run the replace command on layers 1000, 1001, 1002, etc.
Re: Pause at z pos
Posted: Tue Apr 21, 2015 1:02 pm
by JoeJ
Hah oh good point! Just add an extra \n at the end of the replace command and then it will only apply to layer 100 (see below)
{REPLACE "; layer 100\n" "M0\n; layer 100\n"}
Re: Pause at z pos
Posted: Sun Apr 26, 2015 11:50 am
by fantome
How long is the pause? Does it wait for some input from the user?
Re: Pause at z pos
Posted: Sun Apr 26, 2015 1:59 pm
by JoeJ
In case this wasn't mentioned above, this method only works when printing over USB. If you are printing from the SD card, then you are limited by the machine's firmware and if it supports pause commands (some firmwares do, and some don't).
Assuming you are printing over USB, the "M0" command will act the same as if you clicked the Pause button in the machine control panel. You will need to click Resume for the print to begin again.
Re: Pause at z pos
Posted: Sun Apr 26, 2015 4:00 pm
by fantome
I'm using the DaVinci 1. Not sure where it puts the file after it receives it over USB but the DaVinci ignores the M0 Gcode command. I just tried it. I'm going to try the G4 P30000 command, do nothing for 30 seconds. I'll try some other commands related to printing from the sd card.
If anybody already pauses the DaVinci, I would like to know.
Thanks...
Re: Pause at z pos
Posted: Sun Apr 26, 2015 10:41 pm
by fantome
Using simplify3d and all the GCodes I could think of, it seems that the DaVinci printer ignores any code related to pause.
G4; M0; M25 none of these seem to do anything with the XYZPrinting DaVinci printer.
Re: Pause at z pos
Posted: Sun Apr 26, 2015 10:50 pm
by fantome
... I'll try M226 next, Gcode initiated pause. If I knew about this one I would've tried it first.
Re: Pause at z pos
Posted: Mon Apr 27, 2015 5:13 pm
by JoeJ
The da vinci sends the entire file to the machine right at the beginning of the print. So it's unlikely that you will be able to use the "M0" pause feature with that printer since S3D has no idea what line in the file is being executed at any given time. It has to send over the entire file and that's it.
Not sure about the M226 command.. At this point, you are really limited by what the da vinci firmware supports
