aeren
Simplify3D for Wanhao duplicator 5S mini
Fri May 22, 2015 8:28 am
Hi everyone,
Are there any users amogst you who use this software with Wanhao Duplicator 5S mini?
I was using it with the setting file from JetGuy and it was working pretty well, until i made something
where a lot of movement without printing was involved. I got a real spider web there, and i thought it's
not the way it should be. I modified some settings i received from support(more retraction, lower
temperature) but it just became worse. Does any of you have some working settings?
Thanks in advance,
Aeren
KeyboardWarrior
Re: Simplify3D for Wanhao duplicator 5S mini
Fri May 22, 2015 9:58 am
aeren wrote:Hi everyone,
Thanks in advance,
Aeren
When you say spider web, there's two things that come to mind. One would be retraction issues (when the extruder moves from one-spot to another there's not enough retraction) which will cause strings.
The other thing that comes to mind is during under extrusion when there's not enough filament coming out, and that causes a "rats-nest" at times, pretty much just a failed print.
These two things are dramatically different though. If you could post pictures and a factory file of your print that'd be really helpful!
aeren
Fri May 22, 2015 3:38 pm
I believe mine is the first one.
Here are some pics:
And here is the factory file (i used 0.2 layer height with it)
FFF
Thanks in advance,
Aeren
aeren
Mon May 25, 2015 7:03 am
Here is another try:
Sometimes the string is out of the body as well.
TenKOhms
Mon May 25, 2015 9:08 am
try bumping the retract distance to 8.4, and and the retract speed to 3600. Also if you're printing PLA try dropping the temp down to 200
aeren
Mon May 25, 2015 3:54 pm
The temperature is already 200 at start and 190 afterwards, i'll try the rest.
TenKOhms
Mon May 25, 2015 4:02 pm
aeren wrote:The temperature is already 200 at start and 190 afterwards, i'll try the rest.
hmmm, wouldn't hurt to double check, your fff profile has it set to 210 :)
aeren
Tue May 26, 2015 1:28 pm
I set everything, this is the result:
Here is my FFF file.
DarthRevan
Thu May 28, 2015 3:04 pm
aeren wrote:I set everything, this is the result:
Have you tried turning on wiping?
aeren
Sun May 31, 2015 2:48 pm
Hiya,
Not yet, i'm on it.
