Page 1 of 2
Feature request
Posted: Mon Aug 19, 2013 5:28 am
by Shinto
Hello, before s3d Creator I was using Slic3r and I miss some features from it. Like my favorite honeycomb infill and supports with lower extrusion multiplier. Supports made with Creator are very hard to break sometimes, so it will be very cool if I can change an extrusion multiplier to make supports thinner. I'd like to hear other users' opinion so I posted it on the forum and not mailed it directly to support.
Re: Feature request
Posted: Tue Aug 20, 2013 5:25 am
by lllusion
I agree!
I was wondering abt the lack of infill choices too!
Hope they'll provide it in future updates!
Re: Feature request
Posted: Fri Aug 23, 2013 4:12 pm
by sir-mike
I would love to see more infill choices.
About support I think everything you need is in manual support option (Last button down on the right) and also you can play with the support setting "Separation From Part" I use mostly 0.3; 3; 3.
Try it out.
Michael
Re: Feature request
Posted: Mon Aug 26, 2013 4:09 pm
by Shinto
Yes, I know about manual support and I'm mostly using 0.7, 1, 1 settings for layer separation, but sometimes (i.e. to prevent ABS warping) I need to set layer separation to 0. And sometimes supports are melted with main material within one layer. Also (but I need some free time to check this more carefully) I found that models printed in ABS with honeycomb are more resistant to warping (all other settings were similar).
UPD:
If anyone interested I spent sometime printing extruder for prusa i3 with slic3r (with honeycombs) and creator and, unfortunately, creator's extruder is U-bended
In support they reassured me that they are working on new infills, including some mystical _improved_ honeycomb
Hope to see my favorite slicer with my favorite infill very soon!
Re: Feature request
Posted: Thu Aug 29, 2013 6:34 pm
by Aha
I'd love honeycomb back.
One trick if you can't break support or want to fine tune: soldering iron. Yes it's better if the software works, but until then it's like a heated knife through... ice?
Does setting that separation to 0 actually fix the warping on abs at times? I keep running into warping on both pla and abs.
Re: Feature request
Posted: Fri Aug 30, 2013 5:27 pm
by Shinto
Aha wrote:Does setting that separation to 0 actually fix the warping on abs at times? I keep running into warping on both pla and abs.
I have a problem with warping on the edges of overhangs. Supports keep this edges "binded" to a heated bed so they are not curling so much. But when there is a layer separation this binding is broken. Also if you're having troubles not just with overhangs but with warping of whole model and adhesion to the heated bed maybe you'll find something useful here:
http://www.makerbot.com/blog/2011/06/23 ... d-curling/
Raising a heated bed temperature to 110C and printing with high skirt worked for me. Also experiment with cooling. Although it's said that you need to cool your model very fast etc but I found that it's good only for PLA. ABS is curling when cooling too fast. If you're (or anyone) interested in some details or just want to share some printing experience you're welcome to send me a PM.
Re: Feature request
Posted: Sat Jan 11, 2014 9:09 am
by Zeeflyboy
I know it's a slightly old thread, but I would like to put in a request for honeycomb infill too - I've been playing with slic3r a lot lately and find honeycomb better for ABS.
Re: Feature request
Posted: Mon Feb 17, 2014 4:54 am
by glx51mm
+1
Re: Feature request
Posted: Tue Mar 04, 2014 3:21 pm
by davedfx
+1 I need this for strengeth also
Re: Feature request
Posted: Wed Mar 05, 2014 1:23 am
by rmat
+1
