jlspea01
Re: Feature request
Sat Apr 19, 2014 10:26 pm
+1
It's kind of silly that we dont have this. With rectilinear, the amount of layer-to-layer adhesion is reduced since the layers only touch at overlap. For honeycomb, the adhesion is much higher resulting in stronger builds.
CT4
Re: Feature request
Thu Apr 24, 2014 3:15 am
+1
tmoore
Re: Feature request
Thu Apr 24, 2014 11:48 pm
Honeycomb infill is definitely something I would like to see.
bubbasnow
Re: Feature request
Fri Apr 25, 2014 9:06 pm
+10
Jbc
Re: Feature request
Sun Apr 27, 2014 2:10 am
+1
MasterFX
Re: Feature request
Tue May 20, 2014 11:28 am
+1 for Honeycomb
davedfx
Re: Feature request
Sun May 25, 2014 2:33 pm
we need different types of infills and more controls.
Currently the infills are weak especially when used with multiple infill angles say 90,-90, 45, -45. S3d currently lays each line per layer. The default use random infill placement makes things even weaker.
I can hear the infill break when applying pressure to surfaces.
The add solid diaphragm is an odd solution to strengthen parts.
MasterFX
Re: Feature request
Sat May 31, 2014 7:28 am
davedfx wrote: I can hear the infill break when applying pressure to surfaces.
Excaly what I observed. The Honeycomb of Makerware etc. seems to be much more stronger.
