hansen644
simplify printing words backwards now?
Mon Jul 20, 2015 7:26 am
HI last night when printing a word it will only print it backwords? meanding the word is spelled backward. It was working fine two days ago. I must have it some setting not sure what happened? Ideas? It will import the word backwards and print backward so I have tried to do a mirror image and it looks ok in the slicer, but still prints out backward?
Re: simplify printing words backwards now?
Mon Jul 27, 2015 6:28 am
I'm guessing you have one of your axis directions flipped in S3D vs the actual hardware. If you go to "edit process settings", then click the G-Code tab, you can see the "flip build table axis" options on the right side. I'm guessing you need to swap one of yours (likely toggle the X-axis checkbox)
hansen644
Mon Jul 27, 2015 7:51 am
Hi where is edit process setting tab?
Mon Jul 27, 2015 7:53 am
It's a big button on the main window
