allan_glover wrote:Trying s3d v3.1 now with cubepro. I believe the issues though is that I have cubepro firmware 1.14B and it doesn't appear to be able to downgrade. I don't think the codex program works with the latest cube firmware. The gcode looks fine, but it will randomely add in a z lift during a each pass while printing. So as it is moving x and y and extruding it will lift the Z up and down. Anyone else having that issue?
I have this issue on 1.14B too. Did you make any progress?
In case anyone missed it there is a new alternative to CODEX which is significantly faster.
viewtopic.php?f=8&t=5924
I've decoded a sliced file for 1.14B and stripped the starting script out. When this is used with Simplify3D the resulting encoded file loads and dispalys correctly in CubePro, though I've not had a chance to print it, i was not able to check the .cubpro files in Cubepro for 1.14 firmware until I modified the starting script in this way.
^PrinterModel:CUBEPRO
^Firmware:V1.14E
^Minfirmware:V1.14B
^ForceMinfirmware:V1.14B
^DRM:000000000000
^ConfigAndConfiguration:No-
^MaterialCodeE1:MATERIAL1CODE
^MaterialCodeE2:-1
^MaterialCodeE3:-1
^MaterialLengthE1: 1
^MaterialLengthE2: 0.000
^MaterialLengthE3: 0.000
^ExtruderTypeE1:0
^ExtruderTypeE2:0
^ExtruderTypeE3:0
^ModelHeight: 20.000
^LayerCount: 100
^LayerHeight:0.2
^Supports:-1
^Sidewalks:-1
^Density:Strong
^Pattern:Diamond
^Version:1588
^Time:TOTALTIMEMIN
M404 S[bed4_temperature]
M227 P250 S250 G300 F700
M228 P0 S250
M231 P0 S0
M232 P2500 S2500
M233 P1850
M106 P100
G4 P0
M601 P2 S30 F5
M228 P0 S1
M227 P1 S1 G1000 F1000
M240 S1400
M104 S200 P1
M104 S250 P1
G1 X108.000 Y136.000 Z5.2000 F9000.0
G1 X108.000 Y161.000 Z5.2000 F9000.0
G1 X108.000 Y157.000 Z5.2000 F9000.0
M104 S[extruder1_temperature]
M551 P1500 S50
M601 P2.0 S30 F5
M404 S[bed4_temperature] P1
M107
^InitComplete
M104 S260 P1
#Vector T22-1
M228 P0 S250
M103
