The chip is supposed to be mounted on it with 3 posts but instead of slicing the post with a hole in it it kind of hollows it out. Been scratching my head over WHY simplify keeps on doing it. tried slic3r to see why but it happens on there too.
Then there is this weird glitch where it does the same thing with the mounting bracket for the chip's screen. it hollows it out. And for some reason it leaves a square part next to the side by side holes.
Using a sharebot NG dual
The imported file
Sliced model
quick test print final print will be done in 0.05 mm
