bray.christopher
Stratification
Sat Aug 22, 2015 6:31 pm
Any idea what is causing this "stratification"? The spacing seems somewhat regular.
It was printed vertical and it was the only thing being printed.
Ultimaker2.
Re: Stratification
Sun Aug 23, 2015 10:54 am
Maybe it's filament inconsistency. If the filament diameter isn't very tightly controlled, the variations can cause extra extrusion.
I've also had a printer where the vibrations caused similar layers like in your picture.
KC_703
Re: Stratification
Mon Aug 24, 2015 4:32 pm
The only thing I can think of is possibly the solid diaphragm infill setting under the "Infill" tab.
bray.christopher
Re: Stratification
Mon Aug 24, 2015 5:04 pm
KC_703 wrote:The only thing I can think of is possibly the solid diaphragm infill setting under the "Infill" tab.
I wish! That would make sense. Unfortunately that was not turned on. Thanks anyway.
Re: Stratification
Mon Aug 24, 2015 5:56 pm
JoeJ wrote:I've also had a printer where the vibrations caused similar layers like in your picture.
I've had similar where a tall thin part was unstable, so I added pinpoint joined "rocket fins" to steady it:
The fins were twice filament thickness thick and the scarring from the joiners was minimal.
66tbird
Re: Stratification
Tue Aug 25, 2015 12:23 pm
My option is also filament inconsistency. Bigger the piece the narrower the distance between the lines is what convinced me. One day out of total frustration I loaded the cheapest filament I had that I bought on a whim because it was $10/lb. (HobbyKing brand) and ran the job. The vertical wall was flawless.
A roller dial indicator with pcm output for 'on the fly' adjustment has crossed my mind.
turbocharged110
Re: Stratification
Tue Aug 25, 2015 1:06 pm
Have you tried the same part with different layer heights? Could be a rounding error where your microsteps don't match the desired Z-height, so every X layers will be lower than the others with the same material extruded.
Printer: Rostock Max w/ E3D V5 hotend and lots of upgrades/modifications
