jms
Turn Off Comments in GCode
Fri Oct 18, 2013 5:36 am
Is there a setting somewhere that will disable comments in the GCode?
Clayton
Re: Turn Off Comments in GCode
Sat Oct 26, 2013 5:55 pm
Hi jms,
The software will allow you to choose the character that is used to identify a new comment (for most firmwares this is a semicolor ";"). Some firmwares may require a different character, for example I believe the CubeX firmware requires a pound sign "#".
When you upload the G-Code to your printer, these comments will automatically be stripped and only the raw G-Code will be sent.
Does that help you? If not, feel free to contact our customer support staff at support@simplify3d.com and they can provide further guidance.
