giantpune
Re: Where are profiles stored?
Thu Dec 10, 2015 11:34 pm
Simplify3D is written in Qt. The profiles are stored in QSettings (http://doc.qt.io/qt-4.8/qsettings.html). On my Linux machine, they're in the QSettings default location in $HOME/.config/Simplify3D/S3D-Software.conf. You can gather the orginization and application names from that path. And from that, you see the platform-specific notes for QSettings and know where to look. http://doc.qt.io/qt-4.8/qsettings.html# ... ific-notes
Fri Dec 11, 2015 6:31 am
If you want to save the profiles to the disk, just go to File > Export FFF Profile. Then you can put them anywhere you want for safe keeping.
And just so you know, if you export the FFF profile, it also makes it very clear exactly what settings change for High/Medium/Fast quality. Just look at the bottom in the <autoConfigureQuality> sections. It is spelled out very clearly. Just a tip in case anyone didn't know that!
Ursadorable
Sat Dec 12, 2015 9:15 am
CompoundCarl wrote:And just so you know, if you export the FFF profile, it also makes it very clear exactly what settings change for High/Medium/Fast quality. Just look at the bottom in the <autoConfigureQuality> sections. It is spelled out very clearly. Just a tip in case anyone didn't know that!
Oooo.. thank you. Looks like I got some hand editing to do.
