I've done it! (sort of)
I can now successfully print an anchor that primes and cleans the print head before the start of each print. I want to modify it a bit, but here's what I've got so far:
G28 ; home all axes
G1 Z5 F5000 ; lift Z by 5mm
M565 Z-0.57 ; set the offset for auto-leveling mechanism
G29 ; run auto-level
G1 Z0.5 F1200 ; lift
G1 X200 Y5 Z2 F5000 ; move to wait position in right corner
G1 Z0.4 ; position nozzle
G1 E25 F300 ; purge nozzle
M400 ; wait for purge to complete
G1 X25 F1200 ; slow wipe
I would like to have it continue extruding before the wipe, but this has already made a huge difference in my first layer, so excited about this!
KiLLiN-TiMe wrote:I don't have your printer but I never have that issue.
You don't by chance have the print bed too high do you? Maybe your actually scrapping part of the previous line off the print bed and sticking it to your extruder.
I know on my printer there is a fine line between squishing the first layer and smashing it. You obviously want to squish it some so it will adhere to the bed, but if you smash it down it becomes so wide that it interferes with the lines beside it.
You also might want to play with how far you lift the print head between retractions.
Not sure, just a thought.
KT
It's not too close, I've been dialing that down a bunch recently. The issue is the extruder not being primed and junk being stuck to my extruder that sticks to the filament as its laid down, which normally causes the print to form in to a ball. Filament sticks better to filament on the extruder than it does to the bed.
