magicwiser wrote:I agree with the previous post. To really take advantage of the dual extruders, you need to design your model in pieces. However, for your keychain, that can be accomplished fairly easily within S3D. You need to create two different processes, one for the bottom part and one for the top part. Configure all the options for each part (layer height, extruder, etc). Then, in the advanced tab use the 'Start printing at:' and "Stop printing at:' options to control which portion is which. For example, if the base is 3 mm thick, the bottom process should stop printing at 3 mm and the top process should start printing at 3 mm.
I hope that makes sense. If not, let me know and I can clarify.
I have attached a factory file of a print I made last week where I did this exact thing as an example. Check out the advanced tab...
Do you prefer to create Duel Extrusion prints with or without using the "Dual Extrusion Wizard" in the software?
I have never been able to get a successful print using the wizard
