Sun May 08, 2016 10:18 pm
This weekend, I played a little with the printer and using Rigidbot Dual as the configuration worked well. Go to Help, then Configuration Assistant. Just need to adjust the extruder settings. I put Left as T0 and Left Temp as T0, and the Right as T1. And checked marked the Temperature boxes for waiting to heat up.
I did add some small scripts for turning off PLA fan when done, moving the platform down, and insuring the heaters were off.
I don't have the printer connected to the computer and print the from an SD card. The printer is a bit slow on its accelerations, compared to my faster Creator Pro movements. I may have to look into quickening that up some later on.
