spasticken
Does anyone know how to end print job?
Sun Mar 06, 2016 10:29 am
Hello,
After my print job finishes, I would like to have the printer do a few things, turn off fans, Z axis +10.
So far all I can find are absolute G code commands to move the Z axis, is there a command that I can use to make a relative Z axis move?
Also, is there a command to turn off the cooling fan running on the extruder?
Thank you in advance,
Ken
spasticken
Re: Does anyone know how to end print job?
Sun Mar 06, 2016 10:42 am
I suppose I should add to this I believe that M107 RR will turn the fan off, but is there a way in simplify to test this, or how do I add it to the post print procedure?
I am a complete NEWB to 3D printing and am trying to get my stuff together.
Sorry if this has been asked and answered before.
Ken
glsf91
Sun Mar 06, 2016 11:34 am
Add in Tab Script inder Ending script.
I use this:
G91 ;set relative positioning
;G1 E-1 F300 ;retract the filament a bit before lifting the nozzle
G1 Z10 ;lifts the nozzle off of the print
M106 S0 ;extruder fan off
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M84 ; disable motors
Second line is commented out for this moment
spasticken
Sun Mar 06, 2016 11:51 am
Thank you very much!
