Which screw to turn?
Posted: Thu Nov 28, 2013 7:53 am
by Phgeis
HI guys and gals,
I print with an Rteplicator 2x with a lot of mods PLA. I use a fixed multiplier 0.93, retract of 1,5mm and no coast.
Layer hight 1.7
I didn´t following print errors and don´t know how to solve them: to little material on some areas but at the same time to much material at other parts, repeatadly at the same areas and consistent filament diameter.
Some small holes at the end of the perimeter lines.
small blobs at the beginning of the perimeter lines.
Seen from below in comparison with an makerware print the extruded lines seem to far apart.. which setting moves them furhter together?
Which screw should be turned to solve which problem, without increasing an other one?
here some fotos
https://drive.google.com/folderview?id= ... sp=sharing
Re: Which screw to turn?
Posted: Thu Nov 28, 2013 2:34 pm
by Enginwiz
A layer height of 1,7 mm doesn't work for a 0,4 mm nozzle.
Posted: Thu Nov 28, 2013 2:49 pm
by Phgeis
0,170mm sorry
