Advanced FFF Profile Editing - Nozzle Sizes
Posted: Sat Aug 27, 2016 11:22 pm
I've been getting into advanced editing of the xml profiles to add some additional functionality, however this problem as me stumped...
I never really use the "auto-configure for print quality" so I wanted to turn it into a feature that I could use. I have several different nozzles sizes that I can print with, So I am trying to turn that into an easy way to select a nozzle size and preconfigure some of the settings. So far I have been successfully able to edit the name (in the pull down list) and have it populate the Nozzle diameter and extrusion width for the different sizes....
I'm running into an issue because I also want to preconfigure the ooze control and temperatures. The issue with adding those commands to the auto-configure quality XML block is that it will overwrite those values for all circumstances, regardless of the material choosen. Is there a way to have unique values for each material AND the auto-configure quality (as it it were another variable)?
basically I am looking for logic that follows similar to this:
1. select material "A".
2. select nozzle size "from quality auto-configure list"
3. temperature and ooze control settings are prepopulated.
However, currently this flow does not produce unique values for the temperature and ooze control settings. For example if material "B" is chosen and the same flow is followed, it currently gives temperatures and ooze control settings that are the same as material "A" and not unique...
I have tried transferring the <autoconfigurequality> to a heading thats under the <autoconfigurematerial> but that didnt seem to work... anyone have an idea how to do this?
