2.0.1 update osx - any version notes?
Posted: Thu Dec 19, 2013 2:21 pm
by kurios_oranj
hi! came in from work and saw a new version 2.0.1 is available on osx. any documentation on the changes?
thanks for any info
Ku
Re: 2.0.1 update osx - any version notes?
Posted: Thu Dec 19, 2013 6:33 pm
by jimc
thanks for the heads up. i am downloading it now. i havent heard anything.
Posted: Fri Dec 20, 2013 2:32 am
by Kenzu
http://www.simplify3d.com/changelog/
Version 2.0.1
Better error handling for USB upload of poorly formatted G-Code files
Added option for reduced support structure printing speeds
Better retraction movements for complex support structures
Improved behavior for retraction between layers
Verified that correct toolhead is always selected after USB connection is established
Better support for pausing builds mid-print and performing manual actions
Added new options to configure endstop homing directions
Improved temperature auto-configuring so that disabled heaters will always remain turned off
More reasonable limits for extrusion multiplier inputs
Corrected some rare previewer prompts for special case scenarios
Fix for manually turning off secondary extruder when using multiple toolheads
Fix for manually moving multiple models together using the Shift key
Fixed issue where program would close immediately after successful activation on some operating systems
Miscellaneous profile updates
Posted: Fri Dec 20, 2013 12:37 pm
by dalew8abz
Thanks, Kenzu. If that "improved behavior for retraction between layers" is what I think it is, that was my pet peeve. Already downloaded -- let's see what it does with the arch on the torture test!
Thanks to Clayton et al for the fixes! Now I (we?) can't wait to see the manual. ;-)
Dale
Posted: Sat Dec 21, 2013 5:34 pm
by Aha
Did you add back in the Drag and Drop for stl files that seems to have been accidentally removed in 2.0?
Posted: Sat Dec 21, 2013 5:49 pm
by jimc
I was able to drag and drop no problem on 2.0 and the new update. This is on the mac version though
Posted: Sun Dec 22, 2013 2:20 pm
by Zeeflyboy
seems layer heights have gone a bit bizarre (at least on my m2 profile) - is this in accordance with actual steps?
edit - nevermind was just something weird, reset the profile and it's back to normal (albeit with more decimal places than I remember lol)
Posted: Fri Jan 03, 2014 12:48 am
by Manifester
Sounds like it fixed a lot of problems, particularly if you're using externally made g-codes, but rafting is still buggered.
Clayton mentioned to me that soon they'll have an option that let's you do the old style rafting, the new style introduced in version 2.0 floats on a thin layer of support structure -which gives little contact with the bed.
