sreisig1
Tool change retraction script for Dual Print
Mon Oct 03, 2016 6:15 pm
I customized my startup script to retract the idle nozzle after the initial startup wipe/purge that way it doesn't get all over the place when the working extruder does its job for the first layer.
This is the line I added, more specifically the "E" for the idle nozzle for its wipe
G1 X120 Y-50 Z0.15 E-12 F1200 ; slow wipe
All is good up until it comes time to use the idle extruder. I'm using an ooze shield and when it comes time for the extruder/color change it doesn't extrude anything for its ooze shield layer, or the real model, but gets going eventually. Everything after that point is fine I think for tool changes.
Since I retracted the nozzle in the startup script, I assume I now need to prime the nozzle for the first tool change? Is that how I resolve this?
What code do I need to add and where? Tool change scripts?
Re: Tool change retraction script for Dual Print
Tue Oct 04, 2016 7:53 am
Yes, if you retracted the extruder in the starting script then you need to prime it. It's just a simple G1 E move. If you don't know how to do that, it would be a good thing to learn since it's really simple and used constantly by your 3D printer
