SidneyKi
Getting the print off the bed
Fri Nov 04, 2016 11:04 am
Hello,
I had a couple prints I broke trying to get the pla print off the bed.
Any suggestions on making it easier?
Also if I use a raft on the print how to get that off the model with out breaking.
I have a heated bed, printing at 0.4 layer height. The bed just has build tak on it.
Thank you
Sidney
Heutinck
Re: Getting the print off the bed
Mon Nov 07, 2016 1:04 pm
if you are pr9inting on a glass sheet, put it in the freezer for 5 or 10 minutes.
C_Birch81
Mon Nov 07, 2016 3:41 pm
SidneyKi wrote:Hello,
Thank you
Sidney
Is a few things you want to check.
1) First you are using buildtak what's really good, but you want to make sure the gap between the build bed and the print head is bigger than normal, so try doing some test print and each time make the gap a little bigger, because using buildtak you don't need to push the first layer into the bed.
Sometimes it helps to let the bed cool down first also, and don't run it too hot, if using PLA you really should not need to go any hotter than 50c
2) For the raft, you will find a setting for the raft that lets you pick how much of an gap you will have between the raft and first layer of the model, see "separation Distance"
Also it's best to let the print cool down first.
