Perhaps RepG can do that, but S3D does not modify your printer settings. Changing the "Update Machine Definition" section has no affect on your printers max Z height that is defined in the firmware. It is quite easy to verify this by echoing settings from the printer or watching USB communication. So I'm just trying to make it clear that any setting you change in S3D pertaining to Z-height WILL NOT change the firmware Z-height limits. So you still need to fix the firmware or disable the virtual endstops in the firmware.shocksofmighty wrote: S3D (and other software) can override that variable so you don't have to mess with updating your firmware just to change those. I think that's the whole point of that whole "Update Machine Definition" of the gcode section of S3D.
