Solid models with t-glase
Posted: Sun Feb 02, 2014 2:54 pm
by markdahmke
Hi - I'm trying to print a light pipe using t-glase. Is there a way to make it print parallel lines including the infill? Also what combination of settings will generate a large diameter extrusion (similar to the raft) ? I've experimented with setting the nozzle diameter to 1mm with a layer height of .8mm and a print speed of 600mm/min. which works ok except for the infill problem. Suggestions would be appreciated.
Thanks
Re: Solid models with t-glase
Posted: Fri Feb 07, 2014 11:22 am
by jamesarm97
Maybe concentric infill would work better. just a thought. You may need to change the design so you can trim off the ends to allow the light to come in parallel to the infill and not have to go through the ends that may be printed perp.
