I'm trying to figure out the right math/settings to get 3 perfect shells in the walls of my model.
My settings:
Nozzle Diameter : 0.4
Extrusion Multiplier: 1.0
Extrusion Width: Manual 0.4
Outline/Perimeter Shells: 3
Primary Layer Height: 0.2
In my model I made the walls exactly 0.4 x 3 = 1.2mm thick
The slicer decides that there is extra room in the middle and does a wiggly middle shell. I'd like to get this to be a perfectly straight shell like the inside and outside.
What am I missing? Is there another setting that affects how wide the lines actually are?
Is there an overlap setting I'm not seeing?
Thanks for any suggestions,
Chris
