mcamou
Sharing settings between profiles
Wed Jan 18, 2017 12:44 pm
I have several profiles now, basically for different types of filament. However, there are some settings (especially the scripts tab) that I would like to share between all of them, so that when I make a modification it will not have to be manually copied to every profile. Is there a way to do it?
Thanks!
kabali16
Re: Sharing settings between profiles
Wed Jan 18, 2017 3:52 pm
Short Answer: No
Long answer: if you are interested, you can open up the fff profile, which is basically an xml file. Each material config is like a section there, so, instead of having multiple profiles, you can just insert multiple sections here so that all the materials are configured in the same profile
Try reading these posts for more info
viewtopic.php?f=8&t=1989&p=23512&hilit= ... fff#p23512
viewtopic.php?f=23&t=4225
Kabali daww!!
Prusa i3 | Kossel
