phil123456
cannot print slower
Sun Jan 22, 2017 11:54 am
hello,
I try to print a grid of 1mm squared holes separated by 1mm gap, since the resolution of the printer is 0.1, it should work
but I only get crappy prints
I tried lower the speed to 500, but it still prints tiny rings (badly) for the holes outlines
[img]blob:http://imgur.com/d1faabf5-b690-45bc-80eb-4194ee413d75[/img]
how could I manage to print this better ?
brian442
Re: cannot print slower
Mon Jan 23, 2017 4:09 am
Wow, that's going to be a tough part to print! That many 1mm holes is going to be pretty hard for the printer. You can also tell from the picture that part of your problem is that some of the plastic isn't staying in place. So when you trace around the square hole, the actual plastic is moving a bit near the corners. That could be due to overheating, so I would try adding a lot more cooling and, as you said, print it as slow as you can
kabali16
Mon Jan 23, 2017 9:14 am
phil123456 wrote:hello,
Which printer is this ? I see too many rounded corners and incorrect circles. Check if the belt and pulley drive is nice and tight. Another option is to replace with a smaller nozzle (0.2or0.3) if you really want to make 1mm holes.
Kabali daww!!
Prusa i3 | Kossel
phil123456
Mon Jan 23, 2017 3:00 pm
the issue is that the printer (FlashForge Creator Pro) is printing superfast bad circles instead of slow regular squares
I get squares in FlashPrint (the software that comes with the printer) but it does not print any infill between square holes, so I tried simplify3d
wich seems to slice properly but once it's sent to the printer it's a nightmare
now I set the holes to 2mm with 2mm separation, FlashPrint does it fine
but simplify keeps printing the raft super slow (although I set the speed back to normal*) so I gave up
*typical simplify issue I get all the time
phil123456
Mon Jan 23, 2017 3:01 pm
I also ordered a 0.2mm nozzle, I'll give it a try
phil123456
Mon Jan 23, 2017 3:08 pm
here is the result
[img]blob:http://imgur.com/a8408b64-21dc-40a3-8d46-964dfde7ae05[/img]
you can see the 2mm holes print fine, but the 1mm are missing infills in between
as for simplify I already uploaded pictures in my first post
so the printer is not the issue
