peppe64
ONLY WANHAO DUPLICATOR 4
HOW MANY HAVE THIS MACHINE? We post HERE FOR AID AND CONTROLS FOR THE BEST SOLUTION FOR PRINTING
peppe64
Re: ONLY WANHAO DUPLICATOR 4
since I use the version 2 can not work.
someone who uses 4 Wanhao can help me.
Now working again with Replicator G me it works perfectly
I solved the wrong problem in the script, but now I can not warm up the bed.
I enclose my fff
wanhao4.fff
(4.24 KiB) Downloaded 514 times
I dont know of anyone else here with that printer. You may see faster results by emailing support
peppe64
Support does not know the problem, and I saw that others have Wanhao 4 and I want to share with them.
raffo333
Wanhao 4x user ;)
What is your problem ?
p.s. are you italian ?
Ciao
Raf
peppe64
YES is in Italy.
me problem not work for new simply 2 , some problem.
Use FFF replicator 2 , now not work me bed build temperature .
Use Replicator G is fantastic no problem .
Your model FFF to use ??
Make sure you identifier is set correctly. For instance your extruders may be t0 and t1 and your bed might be t2 or t3.
raffo333
Pardon my Italian :)
Ciao Peppe, qual'e il tuo problema ?
