ONLY WANHAO DUPLICATOR 4
Posted: Fri Feb 21, 2014 8:37 am
by peppe64
HOW MANY HAVE THIS MACHINE? We post HERE FOR AID AND CONTROLS FOR THE BEST SOLUTION FOR PRINTING
Re: ONLY WANHAO DUPLICATOR 4
Posted: Fri Feb 21, 2014 9:42 am
by peppe64
since I use the version 2 can not work.
someone who uses 4 Wanhao can help me.
Now working again with Replicator G me it works perfectly
I solved the wrong problem in the script, but now I can not warm up the bed.
I enclose my fff
Posted: Fri Feb 21, 2014 10:52 am
by jimc
I dont know of anyone else here with that printer. You may see faster results by emailing support
Posted: Fri Feb 21, 2014 11:39 am
by peppe64
Support does not know the problem, and I saw that others have Wanhao 4 and I want to share with them.
Posted: Fri Feb 21, 2014 11:44 am
by raffo333
Wanhao 4x user
What is your problem ?
p.s. are you italian ?
Ciao
Raf
Posted: Fri Feb 21, 2014 12:39 pm
by peppe64
YES is in Italy.
me problem not work for new simply 2 , some problem.
Use FFF replicator 2 , now not work me bed build temperature .
Use Replicator G is fantastic no problem .
Your model FFF to use ??
Posted: Fri Feb 21, 2014 6:29 pm
by jimc
Make sure you identifier is set correctly. For instance your extruders may be t0 and t1 and your bed might be t2 or t3.
Posted: Sat Feb 22, 2014 10:32 am
by raffo333
Pardon my Italian
Ciao Peppe, qual'e il tuo problema ?
