docteur.steel
freesculpt ex1 / mayam w150 problem with control card
Wed Feb 15, 2017 8:49 pm
hello
i have a freesculpt ex1 / mayam w150 and extruder doesn 't become hot, and the thermoresitor say all time "23°"
i test the extruder and the thermoresistor, and all seems to be working
and i see electricity is going until the extruder ( even when the printer is on, but not printing : so i think that it 's resident electricity ? in all case 1 think is sure : electricity can go until the extruder , so it's not a problem with the cable that connect )
i think if the printer detect a problem with the thermoresistor, maybe, he block the heating of the extruder ? ( for security issue ) it can be an explain ?
i note that the printer say all time " 23°" , even when i put off the thermoresistor completely, and when i replace it with a 100k resistor
have you any idea ? suggestions ?
i think that id the problem is not the thermoresistor, not the extruder, not cables, it must be the control card ?
have you any idea where i can test it , and find and other ?
thanks !!!
Re: freesculpt ex1 / mayam w150 problem with control card
Thu Feb 16, 2017 7:12 am
I've had this happen before when I had an electronics issue. The temperature would never update since there was a problem with the heater.
