sgertsch
Restrict (Eliminate) Rapid Movement Over Print Area
Sat Feb 18, 2017 5:34 pm
Is there a setting in S3D (or combination of settings and other techniques) to eliminate rapid (non printing ) motion from traversing across a printed area?
This would improve print quality by eliminating the occasional thin whisker of material from being deposited in the just printed layer.
brian442
Re: Restrict (Eliminate) Rapid Movement Over Print Area
Sun Feb 19, 2017 11:25 am
There's the "avoid crossing outline for travel movements" setting on the Advanced tab
Mon Feb 20, 2017 1:10 pm
In my little experience with "avoid crossing outline for travel movements" it only kept it from crossing the outer most perimeter of the print when traveling but still went over the inner surface area. I would like it also if we could make the nozzle detour around so to eliminate scarring type events.
