danlad1631 wrote:Ok thanks for the reply. I've been trying to workout how to do it in solidworks, but I'm not getting very far.
I think the "model it that way" was meant to tell you to orient your print so that the plane you want hex fill to be visible is parallel to the print plate, not that you model the hex infill yourself in a cad
note that if you want to print hex infill that's parallel and not normal to the print bed plane it will have to create a whole lot of bridges (all infill will be bridges) and that's slow to print and is not very strong
There is infill type called "3d honeycomb" or something like that, unfortunately it is not available in s3d, that creates "diamond" shape infill so you have "hexagon's in 3 dimensions" ... I really hope s3d implements that infill type soon
Embed M117 codes into G-Code
open source and unlicence
