Multiple processes not working
Posted: Fri Apr 14, 2017 11:28 am
I have two processes configured. One named "Brim" that adds a brim. Another named "NoBrim" that uses a simple skirt. The only difference between the two processes are the skirt parameters.
When editing each process I use the "Select Models" button to add the desired models to each process. This appears to work just fine. If I Preview each process separately the models are sliced correctly with Brims and Skirts appearing where I want. However, when I "Prepare to Print!" and select both processes and "Continuous printing: layer-by-layer" then the brim does NOT appear in the Preview. And it does not print correctly either.
The Multi-Part Printing Tutorial (Multiple Process, Continuous Printing Mode) shows that this can be done. The instructions are straight forward. Anyone else seeing this problem?
