crazyguy
Increase build area without updating firmware.
Wed Jul 26, 2017 4:09 pm
I own a wanhao duplicator 6 and part of my starting gcode script is to create a purge line at -7 on the y axis. Since my printer is obviously capable of printing oitside of its 200x200 bounds, is it possible to expand the normal build area via simplify3d to 207x207 or higher?
brian442
Re: Increase build area without updating firmware.
Thu Jul 27, 2017 5:04 am
You can change the build size on the G-Code tab in S3D, but if the printer firmware has hard-coded limits, it might not let you go past the stock build size
yonkiman
Fri Jul 28, 2017 1:55 pm
Some flavors of firmware have a gcode command that lets you move outside the defined build area: (http://reprap.org/wiki/G-code#M564:_Limit_axes)
