I am planning to add a glass plate to my (2016 if it's relevant) FFCP. This is because prints are welding themselves to the existing sheet. This is not altogether bad, I know and I can remove the prints.
However, it can be very difficult to remove them and I'm concerned that I'll damage something if I carry on as I am. So, having a removable build plate seems like a sensible solution.
Anyway... I know that if I add the 3mm plate, I'll also have to add a 3mm shim. I'm printing this now. However, is there anything else I need to change to tell S3D/the printer that I've done this? I don't want to cause more damage than I'm trying to avoid.
Thanks,
