So when I print out the tri-fidget spinner in the first picture it comes out perfectly, then using the exact same settings to print the unicorn version it comes out sloped, but if I print the unicorn on my Ultimaker 2 it comes out fine. I would just like to get to the bottom of why it would be sloping when the exact settings on a different item are perfect
The same issue occurs with a few other items I have been trying to print and it only happens on the Deltawasp 2040 Turbo when using simplify 3d, If I slice in Cura it is fine but the final print quality is not as good
Thanks in advance all
