FFCP Banding Around Wall Holes and Other Detail
Posted: Sun Nov 19, 2017 3:40 pm
by swmand4
I'm printing some parts on my Flashforge Creator Pro 2016 and keep seeing this weird banding issue around any walls that have holes in them. It also seems to happen when the outline of an object changes, where detail either sticks out further or cuts inward. It only lasts from the bottom of the hole to the top, and stretches almost all the way around the part. Photos attached. This is not the only part this happens on, any with a change in outline with respect to Z axis result in this defect.
I've tried just about everything I can think of:
Decreasing acceleration settings
Changing print speeds (typically use 3000mm/min)
Printing outlines at ridiculously slow speeds (300mm/min)
Changing number of outlines
Decreasing movement speeds (typically use 4000-6000mm/min)
Changing the order of outlines (inside to out and vice versa)
Changing extrusion multiplier (0.94 calculated for this filament)
Changing outline overlap (20 – 30%)
Varying nozzle temperature (190 – 205C)
Tightening belts
Changing retraction settings (1 – 2mm) and restart distances
Turning off “force retraction between layers” and other ooze control options
Closing the printer door
Opening the printer door and removing the side panels
Changing infill pattern and density (hex/rectilinear 20 – 50%)
Enabling / disabling supports
Turning off “adjust print speed for layers below X seconds”
Other details:
Filament is Hatchbox PLA
Glass bed heated to 60C with hairspray applied (but was still present when using the stock tape that came with the printer)
Micro Swiss hardened nozzle (not all metal hotend, the version for PTFE tubing)
Simplify3D (obviously)
Printer is located in my garage (but defect is still present when printer is in my house)
Printing at 0.2mm layer height
0.4mm nozzle with 0.4mm extrusion width set
Side cooling fan is set to turn on at layer 3
I took a look at the Gcode output in an online viewer and it looks to be doing what it is supposed to
Nothing seems to reduce or eliminate the defect. Any help is greatly appreciated.
Re: FFCP Banding Around Wall Holes and Other Detail
Posted: Mon Nov 20, 2017 12:51 pm
by JasonA
I have a FFCP (same year/make) and I have LOTS of post on this forum regarding the same thing or very similar. I came from the old "woody" FF and another self built printer and had no issues but when I bought my FFCP I had nothing but banding and weird lines and other issues! :shock: :o
I posted here and also on the FF Google forum and had tons of good suggestions but the problem ended up being loose and poorly built X/Y molded rod holders for the gantry. There was a small amount of slop in the molded black pieces that the chrome rods go into that hold the main head assy and that slop was causing the issue! :shock:
But before I found this out, I changed out TONS of stuff, bought 10ft of GT2 belt from Amazon, bought new NEMA 17 steppers, bought new drivers for the main board, swapped out the main board from a buddy's FFCP (after I convinced him).. bought a new Z stepper with the rod (because the Google group said it was prob slightly bent- another $99)... tore the whole machine apart and rebuilt it top to bottom and used locktite... still had the issue.
In the end it was the rails, and there was just enough slop to cause issues. I ended up using 30min epoxy and put everything nice and tight! It's never coming apart or loose and I get amazing prints close to my Mark Forge because everything is rock solid!
One thing to note, if you're using USB, do a test print using the card first! some of the boards had a bad interface and you could be getting lag.
I can take some pics if you want but your issue sounds like a slop or variance issue (aka mech)
Posted: Mon Nov 20, 2017 1:12 pm
by swmand4
Thank you, JasonA, for your reply. In all my Google searching I couldn't turn up a single instance of someone else with this issue. Good to know I'm not the only one.
I have only ever printed from SD card, never from USB, because of the lag issue, potential interruptions, and the fact that my computer is in a different room.
I did a test print in ABS using the right nozzle (as opposed to PLA from the left) and saw that the defect was still there, but less pronounced. I have also tried other slicers and see the problem to some degree or another so I think it's a good bet the issue is mechanical.
Whatever detail you can provide would be great! Photos, descriptions, etc. I think I understand the general concept of what you're saying, but maybe not the finer details... I'll also see what I can turn up now that I have a new slop/variance clue to follow.
Posted: Mon Nov 20, 2017 2:21 pm
by JasonA
Here's some of my posts.... and please take time to read thoroughly through some of them. There's some great info in there! It took me many months to figure this out!!
One thing to note!! The FFCP can be made or shipped with the gantry out of square or like a parallelogram (aka not square to the frame).. pull it close to the front and see if the rails look square to the top (just eyeball it- you can tell right away!) If it's off or not sqaure grab each side and push/pull and you'll make the belts jump a tooth until you square it up. That can cause big issues if you're not square.
Also check the back stepper driving the tension with the short belt--- HAS TO BE NICE AND TIGHT!!--
Here are my posts.. and some vids..
https://forum.simplify3d.com/viewtopic. ... 001#p23001
https://www.youtube.com/watch?v=9JBddNvBKEk
https://www.youtube.com/watch?v=KEn9wfEchuc
Parallelogram
https://forum.simplify3d.com/viewtopic. ... 329#p22329
https://forum.simplify3d.com/viewtopic.php?f=8&t=5059
Posted: Sat Dec 02, 2017 9:26 pm
by swmand4
JasonA - I've read through the material you posted and I think we have different issues. I only have quality problems around certain details - it's actually predictable where the banding will occur (anywhere there is a hole or recessed area in the outline). The rest of the print is very good looking, with the exception of some very minor Z wobble. If I remove the holes from the model, the problem goes away (but then I don't have the holes).
In addition to what I listed before, I have done the following:
  • Checked the Z-axis rod for straightness - it looks fine.
  • Removed the right extruder stepper motor to reduce weight and possibility of ringing.
  • Lowered the acceleration settings in the firmware to match Middleman's recommendation in this post (https://www.thingiverse.com/groups/flas ... topic:8535).
  • Tightened all the bolts again. Every last one.
  • Test printed using Flashprint and as close to the same settings in Simplify3D as possible. While it looked horrible by comparison, it did not have the banding issue.
  • Print using a starting point as close to the hole as possible.
After these items, I have managed to reduce the problem but not completely fix it. If it would help, I could post the Factory file here.
A random thought as I was about to press submit: I noticed an issue with the cooling fan shutting off during process changes for a different part. This issue was causing banding at the process change height, and it went away once I corrected the fan issue. Note the model in question here uses a single process. However, I wonder if, due to the model geometry, the model itself is blocking the cooling fan when printing on that side (fan blows mostly on the plastic infill, not on the side.) This might explain why the defect is most prominent on the right side and fades as it follows the cylinder. It would not, however, explain why the defect can sometimes be seen on the other side. I suppose I could try rotating the model 180 degrees, print again, and see if the defect moves to the other side...
Posted: Tue Dec 19, 2017 2:48 pm
by swmand4
Printing in various orientations (90, 45 degree increments) did not change or reduce the effect.
Printing with various cooling fan settings did not change or reduce the effect.
Attached is another example of the issue on a couple other parts. Notice the areas circled in red - the effect is present only at heights where there are holes in the wall. And some effect in the area in blue, though not as bad as on the part in previous posts. In fact, the other side of the blue area is raised instead of recessed, almost like a layer shift but only at the heights where the details are. Everything returns to normal once getting past the holes/recesses.
Any ideas, anyone at all?
Posted: Tue Dec 19, 2017 6:45 pm
by horst.w
I think, it is not a problem of your printer, I have the same occurrence with my Mankati Full XT.
I can not avoid it but minimize when reducing the speed. But the band seems than like an area what is more compressed and more glossing than the rest of the object.
At the moment I print a lot of small objects with reduced acceleration and only 40 mm/s in a really pretty quality and no bands at all. The edges are all accurate and knife-sharp. Maybe I have changed from a 0.40 nozzle to a 0.30 nozzle, perhaps the problem is caused by the (old) nozzle.
Regards
GER
Attached a picture of my test- bloc for bridging and hole; in the worst case, a band ist as large as the hole wide. Theoretically the bridge has similiar conditions as the hole, but I have never seen a band there!
Posted: Wed Aug 15, 2018 11:39 am
by swmand4
Backing off the speed never seemed to reduce the problem for me. The only thing that helped was switching to a different filament brand. I almost exclusively use MakerGeeks PLA now. Barely, if ever, see this problem anymore. Maybe it's the higher temps their PLA prints at, or maybe I tweaked some other setting. At this point I may never know.
