Reverting to Saved Process vs. Modified Process
General discussion - share tips, talk about machine specific issues, and showcase your latest prints
Geek2Nurse
Wed Dec 13, 2017 12:27 pm
I save processes based on my printer model + filament type, once I've dialed in the settings that work best for each filament. But if I modify one of those processes for a specific print, I don't always want to save the changes to the process; I might just want to save them to the factory file for that print. However, once I've made modifications, I can't find a way to revert back to the original saved process. The only version available in the dropdown is the modified one. I don't always remember every single thing I've tweaked; that's WHY I save the base process, so I can go back to it. Except I can't. What's the point of noting that the process has been modified if the unmodified version is no longer accessible? What am I missing?(Version 4.0.1)
rrdavis
Re: Reverting to Saved Process vs. Modified Process
Thu Dec 14, 2017 3:48 am
Just select any other profile in the list and it will ask if you want to save the modification you made. Choose NO, and then those modifications will be erased. You can then switch back to the original profile, free of any modifications.
Geek2Nurse
Fri Dec 15, 2017 4:20 am
Not exactly elegant, but at least it works. ;) Thanks!
Return to General Discussion and Tips
